Android Datalogic SDK uses-library
Hi Datalogic,
I’m trying to integrate datalogic android sdk to our application.
I checked the manual (Datalogic Android SDK | Technical Documentation) and find next:
“Datalogic device compatible apps, relying on Datalogic SDK, require a mandatory change to the Android application manifest in order to work…”
Does this relates only for * SDK add-on component implementation? Or for both implementation (including Maven dependency (Recommended)) ?
Note: It has completely clear reason for SDK add-on component, as we compile app with custom SDK so we do limit app usage only to devices that are using it. However I don’t see why it should be added in case of dependency implementation, yet your sample app DecodeListener do exactly like that.
Thanks,
Vitalii
