I have a Datalogic Skorpio X5 XLR and when I use scan2deploy Studio to install the Scannercamera app (com.datalogic.scannercamera) the command failed. I have Android 13 and 11 OS scanners. Run Script - Enable App - com.datalogic.scannercamera - Command failed. The package only has this app enabled with no other options enabled.
Hi Paul,
Welcome to our forum. ![]()
I’m a little puzzled. Our Skorpio X5 XLR units come with Scanner Camera pre-installed in the firmware. The command to install it is probably failing because it is a system-signed app that users do not have permission to replace. Which firmware version are you running on your Skorpio?
Kind regards,
Scott Kucera
Mobile Computer Specialist Support L3 Engineer | Datalogic
Hi @Paul_Terriault,
My guess is that the scannercamera is not installed on your skorpiox5. If I remember correctly in the past it was not present in the espresso firmware.
I would advise to install the espresso firmware mathing your scanners firmware. You can find the (espresso) firmware here: Skorpio X5 - Android - Firmware - Products - Datalogic Developer Portal
Espresso firmware can be installed on the same way as a normal firmware. Manually, via adb or via Scan2Deploy Studio.
