I am trying to start Scan2Deploy on android from our app using a launch intent. I am following this manual from Github
But I encountered two problems.
The package name in the manual is incorrect. After removing
.androidfromcom.datalogic.android.scan2deploythis was fixed -
I could not generate encoded data using
dl_config.exe --encodeonly=true
According to the documentation something like this should happen:
> dl_config.exe lock-test.json --encodeonly=true
Datalogic Staging Configurator (ver 1.6.0)
Copyright (c) 2016-2018 by Datalogic MCSA S.r.l.
Loading file 'lock-test.json'
Processing data
-----BEGIN ENCODED DATA-----
Bm9uiYeZ/NWOnA0ZtIrgLMe1iTFLmjusB6P7S4z/lVZ7LFk1d++YM73GqVnqsT9dmxEEuWfR9My93fUA2tUcEv+jxlGNjljHQpXt96BvbVR8bokir3SsXTnFU3qTDeZznLs3PFh+O3n59luLWVNR3c2mFJF5vaGmLue6xHi3bwJgrZOKzs3/bpibCqeNBLcHa/zQRCPQw4=
-----END ENCODED DATA-----
But I don’t see the option --encodeonly=true in the usage in my dl_config.exe from DXU v2.0
Copyright (c) 2016-2017 by Datalogic MCSA S.r.l.
ERROR: bad argument(s) in command line
Usage: dl_config.exe <input-file> <output-file> [options]
Options:
--outputfolder=<string>
--barcodetype=<1d|2d>
--barcode1dlimit=<integer>
--barcode2dlimit=<integer>
--legacymode=<boolean>
--version=<integer>
--enroll=<boolean>
--description=<string>
When I try running with --encode-only, I get just a PDF File.
Could you provide me the right dl_config.exe?
Thanks,
Jan van Rosmalen
