Error in SDK AddOn files of new release v1.28?
The provided SDK addon packages (like datalogic-sdk-v1.28-30.zip) seem to contain datalogic.jar files of the previous version v1.27.
After updating to version 1.28 In the Android Studio editor com.datalogic.device.info.SYSTEM.SDK_VERSION is still resolved to “1.27”.
Opening the file /META-INF/MANIFEST.MF in the datalogic.jar library file, I also find a line with “Implementation-Version: 1.27”.
Can you check this please?
Hello @Richard_Venderbosch
Thank you for this message. You found a problem that we were not aware of. While the SDK distributed through the Maven repository was correct (see: Datalogic SDK | Maven Dependency), the Add-on v1.28 publishing script for some reasons had failed.
Now we have fixed the issue and you can download the correct Add-On again.
Unfortunately Android Studio does not provide an automatic recovery system for cases like this.
All users who have already downloaded the wrong Add-On will have to manually remove it from their Android Studio installations and download it again.
To do this, in Android Studio:
  • open the SDK Manager,
  • enable the check box “Show Package Details” in the lower right corner,
  • check the entries “Datalogic SDK v1” that are affected,
  • un-check the corresponding checkbox and press Apply (the corrupt package will be removed)
  • now select again the corresponding checkbox and press Apply. The updated package will be downloaded and installed.
Best regards
