How to get the Caps Lock, YELLOW or BLUE keyboard state on Datalogic Android Devices
Hello @Stefan_Klammer ,
Unfortunately, despite the presence of SDK 1.22 onboard, Memor K does not include the Advanced Keyboard functionalities available on Skorpio X5, that allow the Multitap delay management or the option for installing Custom Keyboard Layouts.
But I don’t perfectly understand what you mean with “get some Multiple Reads with the Front Trigger”.
If you need to insert a delay after each code reading, you can temporarily disable the device’s triggers (or the Keyboard Wedge depending on the architecture of your your application) and then enable them again after a defined period of time, or when the logic of your application determined that you can read a new label.
You can find more information in the article: How to enable/disable the Scan Engine through Android Studio SDK
If you need more support, consider also to open a tech request via the company’s tech support portal available here
Mobile Products L3 Specialist SW Engineer
