Hi, I have several Memor 10 units, after shutdown or reboot the settings I set are reset.
I set it up like this -
Datalogic settings - Scaneer & decoder - Good read - Enable Green Spot - off. After rebooting it is still set to On
Datalogic settings - Scaneer & decoder - Wedge - Keyboard wedge input mode - Key pressure. After rebooting it is set to Text injection
Build version 2.10.16.20220308 Android 9
Previously there was another version of Android 9 on the forum read that you need to put newer versions but after installing still the settings are confused. Please help
Hello @Marat_Bokhashov
This is not an expected or known behavior.
The first advice we can give you is to update the FW of the device to the latest version available (see: Memor 10 - Android - Firmware), then perform a factory reset, reconfigure the device and check if the issue persists.
If the bad behaviour still occurs or you need any further info, please open an official ticket via this link: Technical Support - Datalogic.
Our technical support service will follow up your case directly and take care of it.
Datalogic Mobile L3 Products Specialist - Software Engineer
