Memor 10 Screen capture
IS there a way to screen capture on the Memor 10 without using an MDM or the DXU utility?
Hi Adam_Brumwell,
there are applications in google play that allow you to take screenshots, can you use one this apk?
Regards,
Hello Adam_Brumwell,
Welcome to the forum.
as with any Android device, you can capture the screen of your device using the standard “Power + Volume Down” key combination. This link completely describes the simple procedure.
Otherwise, you can also rely on any public app capable of that function. An example would be Screenshot Easy https://play.google.com/store/apps/details?id=com.icecoldapps.screenshoteasy.
If, instead, you have to capture the screen for the remote control, you will probably need some remote viewing application, like MDM or DXU. Other alternative remote apps could be TeamViewer, Vysor or other similar apps.
