I’m trying to use the PackageInstaller class of the SDK (PackageInstaller - Datalogic SDK version 1 | Android Add-on), but the method always returning [UNBOUND_SERVICE]. But I not find any clue to this type of error
Any help will be appreciate
Hi @Donato_Cataldo :
Firmware: 1.11.24.20210517
SDK Version: 1.27
Android: Oreo 8.1
The relevant code:
val packageInstaller = PackageInstaller(applicationContext)
val listener = PackageInstallerListener {results: MutableList<PackageInstallerResult>? ->
if (results != null) {
for (result in results){
Log.d("Listener", result.result.toString())
packageInstaller.install(apkFile?.path!!, false, listener)
The Log:
D/DL - PackageInstaller: PackageInstaller()
D/DL - PackageInstaller: install(/storage/emulated/0/Download/Neo.OSB.App_0.9.apk,false)
createSession()
D/DL - PackageInstallerSession: PackageInstallerSession()
D/DL - PackageInstallerSession: openSession()
D/DL - PackageInstallerSession: install(/storage/emulated/0/Download/Neo.OSB.App_0.9.apk,false)
D/DL - PackageInstallerSession: PackageInstallerCommand(command= [INSTALL_CMD], /storage/emulated/0/Download/Neo.OSB.App_0.9.apk)
closeSession()
bindPackageInstallerService()
D/DL - PackageInstallerSession: prepareResults()
D/DL - PackageInstallerSession: prepareResults(INSTALL_TERMINATED_EVENT_NAME, /storage/emulated/0/Download/Neo.OSB.App_0.9.apk, UNBOUND_SERVICE)
Tnks.
Hi @Paulo_Ventura,
the “packageInstaller” feature (PackageInstaller - Datalogic SDK version 1 | Android Add-on)
unfortunately is not supported for Android 8 M10, it is supported for Android 9 M10.
If your environment allows it, our suggestion is to upgrade your system to Android 9.
Note: keep in mind that if you upgrade your M10 to Android 9 you cannot roll back to Android 8.
Best Regards
Donato Cataldo
