How can i set the Language of the device with DXU or with SOTI ?
Im using AE with SOTI, so setlocale doesnt work anymore. I cant find it also in the DXU Configuration.
Hi Michael,
for the M10 the adb command to set the “Language-Country” is this :
adb shell settings put system system_locales it-IT
The above adb command sets the “Language-Country” in “it-IT”, after a reboot you can see the setting applied.
You can set the “Language-Country” also with DXU (in the example is set to “fr-FR”)
If you want to set the “Language-Country” with Soti you can send the “.dxu” file to the device and apply the configuration with the “APPLY_SETTINGS” intent (https://developer.datalogic.com/mobile-computers/news/android_intents).
In all these cases the configuration takes effect only after a reboot.
If you are configuring the device with the “Android Enterprise QR”, you can set the “Language-Country” in the QR code through the “Additional Android Enterprise properties”.
Link to the QR code generator: https://datalogic.github.io/aeqr/
link to the documentation: https://datalogic.github.io/aeqrdoc/overview
The above adb command sets* the “Language-Country” in “it-IT”, after a reboot you can see the setting applied. You can set the “Language-Country”Your environment must meet the following requirements to slope unblocked successfully install and deploy SOTI MobiControl. Unless noted, these are the minimum requirements … I am fairly new to the Soti Mobicontrol platform. I have a Dxu file that I have managed to send to a Memor 10 in the sdcard\download folder . What I don’t know …
