Is there a way to turn on and off the scanner by sending a broadcast intent?
I mean something like:
val intent = Intent()
intent.action = “com.datalogic.some_api”
intent.putExtra(“some_parameter”, “disable_scanner”)
sendBroadcast(intent)
Welcome on this forum,
unfortunately at the moment a broadcast intent that enables/disables the scanner is not available.
As suggestion you can develop a receiver (documentation here) that through an explicit intent can enable/disable the scanner with this code (reference here) :
import com.datalogic.device.input.KeyboardManager;
import com.datalogic.device.input.Trigger;
KeyboardManager keyManager = new KeyboardManager();
for (Trigger trigger : keyManager.getAvailableTriggers()) {
boolean result = trigger.setEnabled(false);
if(result){
//operation done
}else{
//do something in case of failure
if you need more information on this topic please contact our technical support:
https://www.datalogic.com/eng/contact-us/technical-support-cts-8.html
Best Regards
Donato
