First error: KEYCODE_BARCODE missing
We have hundreds of memork devices and we want to remap some keys because we have a lot of scan buttons failing…
For example, If we made this changes on “datalogic settings” on android, we have an option to replace source button “down” with ramaped button “barcode”.
If we want to do this with scan2deploy we have the option to select source key, but “barcode” option is missing on “remaped key”… If you open the tar file and edit the profiles.json like this:
ORIGINAL: _______________________________________________________________
“KeyRemappingFrom”: {
“remapSourceScancode”: “VSCAN_DOWN”
“KeyRemappingTo”: {
“remapTargetType”: “KEYCODE”,
“remapTargetKeycode”: “KEYCODE_BACKSLASH”,
“remapTargetMetaState”: “NONE”
EDITED: __________________________________________________________________
“KeyRemappingTo”: {
“remapTargetKeycode”: “KEYCODE_BARCODE”,
It works fine, but this is very tedious…
Second error: BTN_MODE option missing
There is no option to add to remaped buttons the BTN_MODE also call K2 in scan2deploy studio. This doesn’t work even with manual edition.
Third error: proxy problems
there is a bug on proxy configuration where if you put a url like this: “proxy01.asd.es” it says “proxy host must be a url or ip” and settings cannot be saved.
so…
proxy01.asd.es is not valid
proxy1.asd.es is valid
proxy0.asd.es is valid
proxy.asd.es is not valid
proxy001.asd.es is valid
proxy001343.asd.es is not valid
proxy00143.asd.es is valid
Fourth error: code128 L1 length
We have a problem where if we edit the option in symbology settings → barcode → code 128 → L1 length to 1 it doesn’t change at first time when the qr code is scanned. If we do a second scan of the qr code, then it changes.
So we format the memork, do the configuration with qr code and code128 l1 length is not changed but other options are made ( apps installed, scripts running, etc…) , and if we go to scan2deploy and read the code for a second time, it does the change to l1 length
