PM9600 with CM9681 Ethernet communication not sending results to PLC
I have a PM9600 scanner with a CM9681 Ethernet communication module connected to a Siemens S-1500 PLC with TIA Portal V20 software. I’m using DAD mode for communication. Everything is ok on the connection, syncronization works fine. But…when I’m scanning a barcode I’m not receiving any result in the PLC.
I tried everything I found in the documentaion, regarding the pairing of the scanner with the base, but still not working. The leds are green on the base and scanner. When I connect the scanner with the base, I can hear 2 beeps. I don’t know if this is ok, as in the documentation is written I should here more ascending beeps tones.
Could you please provide support or guidance regarding this issue?
Thank you.
Hello @Bogdan_Ionita ,
This forum is mainly meant to provide general information on Datalogic Mobile products, mainly Android devices.
Some useful information on PowerScan 9600 devices and CM9681 Ethernet communication module, can be found on the “Manuals & Technical Doc” section of the page: PowerScan 9600 Series: Industrial Handheld Barcode Scanner - Datalogic
However, you can get direct support by contacting our local technical support team through the Contact Us - Datalogic page (local support available, via web, phone and email).
Regards,
Simone
Hello, I’m curious how did you get this working, I am having a similar problem. Thank you
Hello @Melinda_Timma
To get specific support on PM9600 scanner and CM9681 Ethernet communication module, we invite you to contact our local technical support team through the Contact Us - Datalogic page (local support available, via web, phone and email).
