I use this method to grant permission which is declared in manifest it work fine with standard permissions but using ACTION_MANAGE_OVERLAY_PERMISSION and ACTION_USAGE_ACCESS_SETTINGS for both it’s not working please suggest me what i can do?
This are action names, not permission names.
You can use these names for launch intents to open the appropriate system settings dialogs.
Use permission “SYSTEM_ALERT_WINDOW” for drawing over other apps and “PACKAGE_USAGE_STATS” for accessing usage statistics.
Yes, I have declared SYSTEM_ALERT_WINDOW and PACKAGE_USAGE_STATS in the manifest, but this method Public int grantPermissions (String packageName, ArrayList permissions) doesn’t work for these permissions.
It only works for standard app permissions, like android.permission.CAMERA,android.permission.READ_CONTACTS etc.
Can you tell me how to enable special access permission without asking the user manually?
There is no general way to get these permissions without user interaction - at least for standard applications.
Maybe Datalogic is able to extend the “grantPermissions()” API method for these runtime permissions in a future SDK release ![]()
Permission like SYSTEM_ALERT_WINDOW, PACKAGE_USAGE_STATS, MANAGE_EXTERNAL_STORAGE and many others, are part of a set of special signature-level permissions shown under:
Settings → Apps & Notifications → Advanced → Special App Access .
Those permission are not directly managed by the Package Manager (pm), but by Application Operation (appops), a secondary framework for controlling permissions. To either deny or allow an “AppOps” permission for an app, you can do it - for testing - through adb:
adb shell appops set [--uid] <PackageName> <PermissionName> ignore
adb shell appops set [--uid] <PackageName> <PermissionName> deny
adb shell appops set [--uid] <PackageName> <PermissionName> allow
These SHELL commands are strictly controlled by the Android, and by default neither Third Party app or even System app can invoke a shell command interacting with the Appops framework (only ADB is allowed).
In deploying apps in enterprise environments this could be a limitation.
Starting with firmware versions that include SDK v1.34.4 (see “Supported Devices” compatibility table in SDK documentation), Datalogic whitelisted Scan2Deploy Agent so that it can execute the command through script.
This is an example on how to allow the “MANAGE_EXTERNAL_STORAGE appops” to a package using a script of Datalogic Scan2Deploy Studio:
Select “SHELL” then add:
appops set --uid <PackageName> MANAGE_EXTERNAL_STORAGE allow
This is the list of devices and firmware that already (September 22nd, 2023) include SDK 1.34.4:
- Skorpio X5 Android 11: fw3.21.001 released on 2023-08-28 | SDK 1.34.4
- Memor 20 Android 11: fw3.22.001 released on 2023-08-28 | SDK 1.34.4
- Memor 11 Android 11: fw1.03. 07 released on 2023-09-31 | SDK 1.34.6
JoyaTouch 22** Android 11 will include SDK 1.34.4 on the first available FW release.
@Richard_Venderbosch, @Bharat_Kumawat, we were listening to you! ![]()
Mobile Products L3 Specialist - SW Engineer | Datalogic
See also:
https://developer.android.com/reference/android/app/AppOpsManager
Hello Simone, there is a similar command to enable the accessibility option on a specific app?
I found the command “adb shell settings put secure enabled_accessibility_services package/service” but it seem to fail when added with the SHELL script command.
Hello @Marco_Senigagliesi
I have not directly verified the parameter you indicated, but i see that you’re trying to set it as an Android secure setting. In that case, for secure, system or global settings, the Scan2deploy 's SHELL script command is not able to change them directly.
That is why Scan2Deploy scripts offer the “SET_SETTING” command.
Could you try that?
Hello @Simone_Callegari , thanks for the suggestion, after severa attenp i found the correct command with “SET_SETTINGS” and “SECURE enabled_accessibility_services it.nanosystems.supremo.addon/.SupremoAccessibilityService”
Thanks a lot!
