Hello everyone,
I am extracting only a part of a GS1-128 barcode using a formatter. The following conditions apply:
- The string has 24 characters
- The 20th character is a letter
- The code starts with 4 letters
If all conditions are met, the last 4 characters of the string should be returned.
The issue I am facing is that the control character “]C1T” is always included. How can I remove this control character in the formatter so that only the last 4 characters of the string are returned?
Many thanks for your help!
Regards,
Benni
Hi @Benjamin_Schurr,
I would love to help you with your Visual Formatter project. Can you please share a good photo of an example barcode? And define the projected output? This would help me a lot. Thanks!
P.s. working with the length of a GS-128 barcode can be tricky because of the non-printable characters.
Gr Peter.
Hi Peter,
thanks a lot for your help. Please find attached a photo of the barcodeTWBD2031495700000000T436.
The desired output should be only the last 4 characters of the string, without any control or non-printable characters.
Gr
Benni
Thank you for the barcode. I replicated your project and made some minor changes. It seems to work fine like this:
Not sure you ment that you did need a LF at the end of the stripped barcode or not. But in my example it does not.
Let me know if it works or not.
Hello Peter,
thank you for your help. It works perfectly.
Gr Benni
