Sending non-protected broadcast using Intent Wedge
Hello @matt_daniel
I think the app isn’t receiving the barcode data because of a mismatch between how Decode Wedge sends the intent and how the code receives it.
in your code you use:
  • An [IntentFilter] attribute on the Activity
  • OnNewIntent() method to handle intents
This approach works ONLY if Decode Wedge is configured to use START_ACTIVITY mode.
However, in your case Memor 30’s Decode Wedge is configured to send BROADCAST intents (as you can see from the log message “Sending non-protected broadcast…”).
The difference is that while with START_ACTIVITY the Intent is delivered directly to an Activity (explicit intent) → triggers OnNewIntent(), with BROADCAST, the Intent is sent as a broadcast (implicit intent) and requires a BroadcastReceiver to intercept it.
As a result the IntentFilter attribute and OnNewIntent() method are never triggered by implicit broadcast intents.
The solution I would suggest is to create and register a BroadcastReceiver dynamically in code.
Code sample:
protected override void OnCreate(Bundle savedInstanceState)
      // BroadcastReceiver registration
      var filter = new IntentFilter("com.datalogic.decodewedge.decode_action");
      filter.AddCategory("com.datalogic.decodewedge.decode_category");
      RegisterReceiver(new DecodeReceiver(), filter);
// Receiver
public class DecodeReceiver : BroadcastReceiver
    public override void OnReceive(Context ctx, Intent i)
        var data = i.GetStringExtra("com.datalogic.decode.intentwedge.barcode_string");
        var type = i.GetStringExtra("com.datalogic.decode.intentwedge.barcode_type");
SW Engineer - Mobile Computers L3 Support | Datalogic
