Skorpio X5 - SSL connection issues with RSA certificate
We are using Datalogic Skorpio X5 barcode scanners running Android 10 with our own .NET MAUI application.
The application connects to our own REST API, hosted on a Windows IIS server over HTTPS.
We recently switched the SSL certificate on our API from ECC (ECDSA) to RSA (4096-bit).
Since this change, our application can no longer connect to the API due to SSL connection errors.
The API itself is accessible through a web browser, but the connection from our MAUI application fails when using the RSA certificate.
As Android 10 normally supports RSA certificates, we would like to understand what could be causing this issue.
Our questions:
  1. Are there any known SSL/TLS compatibility issues with RSA certificates on the Skorpio X5 running Android 10?
  2. Could this be related to the Datalogic firmware or Android security configuration?
  3. Is there a firmware update or configuration change that could resolve this issue without upgrading Android?
Any advice would be appreciated.
Thank you!
