Soti Script : Firmware update:
sendIntent-s "intent:#Intent;component=com.datalogic.systemupdate/com.datalogic.systemupdate.SystemUpgradeService;i.action=2;S.path=/sdcard/firmware.zip;i.reset=0;i.force_update=0;end;"
Soti Script: DXU Config:
sendintent -b "intent:#Intent;action=com.datalogic.dxu.Config;S.config=/sdcard/joya.dxu;end;"
For our Android 4.4 firmware upgrade you need to use a different script:
sendIntent -s "intent:#Intent;component=com.datalogic.systemupdate/com.datalogic.systemupdate.SystemUpgradeService;i.action=2;S.path=/storage/sdcard0/firmware.zip;i.reset=0;i.force_update=0;end"
I´v tried to update the Firmware of a Memor 10 thru SOTI, i used this script:
sendIntent-s “intent:#Intent;component=com.datalogic.systemupdate/com.datalogic.systemupdate.SystemUpgradeService;i.action=2;S.path=/sdcard/memor10-ota-row-1.02.07.20190415.zip;i.reset=0;i.force_update=0;end;”
After Download of the File , nothing happend, but the File was on the device.
With System , Update search manualy, i found the Package at /sdcard/ Folder
Hi Michael,
Just gave it a try. This worked for me:
sendIntent -s “intent:#Intent;component=com.datalogic.systemupdate/com.datalogic.systemupdate.SystemUpgradeService;i.action=2;S.path=/storage/emulated/0/memor10-ota-row-1.02.07.20190415.zip;i.reset=0;i.force_update=1;end”
I’m having issues updating firmware using the 1.05.13-1.07.15 incremental. It’s really hit and miss on whether or not the intent works for me, but if I go into system on the device and select the update it will apply.
Is there a log file somewhere where I can review what the intent did or did not do? Perhaps the issue is power conditions? Nothing gets reported back to MobiControl so I am left grasping at straws.
can you please file a case about it here?
https://www.datalogic.com/eng/contact-us/technical-support-cts-8.html
this way our team can perform some tests from our end and then follow up on the issue
