Upgrade Firmware Skorpio X3
Good morning
I hope some of you can help me out. We have 4 Datalogic Skorpio X3 scanners with very old firmware (exactly 1.81.072.01) and we would like to update them to the latest version, as we have encountered several problems. We have looked for the latest updates on the site but we can’t find / download them.
(link -> http://download.delfi.com/default.asp?dir=Datalogic…{OriginalLinkRemovedByForumAdmin}.
Could you tell us an alternative site where you can download them.
Thank you in advance for your help!
Skorpio X3 firmware, as for any obsolete device’s firmware, can be found on the “Partner reserved” area of our public website.
You can register you account and access this area using the proper “Partner Login” link on the top right of our website’s homepage, or by following this link:
https://partnernet.datalogic.com/search/index/sf
this link will open a Fast Search page, where you can filter by Product = “Skorpio X3” (look under “obsolete products”), Category = “Software &Update”, then by typing “firmware” into the “Search by keyword” filed.
This will result in a list of all the available FW for Skorpio X3 devices.
The latest firmware for Skorpio X3 device is SKORPIO_X3_CE6.0_ver_2.30 (57Mb) available hat this link
New firmware OS images can be loaded on Skorpio X3 CE devices by using the latest DATALOGIC FIRMWARE UTILITY (DFU) V4.8.19.0 available at this link
Salve, il link proposto per il firmware SKORPIO_X3_CE6.0_ver_2.30 non funziona, potete controllarlo? Ho bisogno forse di autorizzazioni per lo scaricamento?
Hello Simone,
For opening the provided link, you need an account for accessing our "Partner reserved” area (Link on the top right part of our public website home page, or for convenience
here) .
If you do not have an account, please fill the proper registration module available form the page, or here.
Hi Simone, i already create an account.
Need i some other autorizations?
My account is create wth my e-mail address, but when i click on link, browser go to home page https://partnernet.datalogic.com/home/index/sf
Hello Simone,
After submitting the registration form it could take some time for processing, but when you have your credentials, https://partnernet.datalogic.com/home/index/sf brings to the " PARTNER ADVANTAGE PROGRAM" home page, where on the top you can already find a first “Search” tool. If you specify “skorpio x3 firmware” in the search field, you should get a list of all the available skorpio x3 firmware.
Otherwise you can directly use the already provided link to the latest SKORPIO_X3_CE6.0_ver_2.30 firmware version.
If your account registration problems persist, I suggest you open a support request at https://www.datalogic.com/ita/contatti/supporto-tecnico-cts-8.html, where one of our technicians can help you
Boa tarde,
Também preciso do firmware do Skorpio X3.
Peço o link com urgência.
Att.
NEWWARE SOLUTIONS
Hello @LINNEU_FIOLO_FILHO ,
For SX3 firmware and other legacy devices download references, please see the answer to this thread here above.
Regards.
hi
does SX3 download files are all gone?
i cant find any
all i get from search in the site is “no item found”
Hi @Kourosh_Bazlpour
The Skorpio X3 product line is quite dated, and had already been replaced a few years ago by the newSkoprio X4 series.
If you need support material for obsolete product lines such as Skoprio X3, you can find them on our Corporate Extranet at https://partnernet.datalogic.com/ .
I invite you to read also this answer for more information on how to find material for Skorpio X3
there no such thing as “Partner Login” on https://partnernet.datalogic.com/
Hello @Tomasz_Raczynski,
As indicated on the previous threads, tIf what you need is any legacy Skorpio X3 firmware,
The resulting page return all the available firmware download for Skorpio X3.
What are you precisely looking for?
Simone
Hello @Simone_Callegari ,
I’m trying to get hold of the legacy Skorpio X3 firmware and there is no subsection called ‘Software Download’ under Technical.
Can you please point me in a right direction where this has been moved or provide a direct link to it?
Regards,
Dins
Hello? nobody help? I need the firmware too
Hi i’m registered as partner but can’t find any links to the skoprio x3 firmwares.
Can you help?
Hello Simone_Callegari,
unfortunately there is only a “Developer’s Portal” under the item Technical and no “Software Download”!
The link in the answer above, which was shared by you, also does not work.
Would it be possible to put the ZIP file of the firmeware into a Google Drive or similar so I can download it?
Thanks for your help in advance!
Alexander Polt
The download section of the Datalogic Corporate Extranet website available at https://partnernet.datalogic.com/ is reserved to direct Datalogic customers only.
After the registration, you are enabled to a basic access that shows some public link and some documentation. In a second step, the website will recognize if your registration email is associated with an order and will give you full access to all sections of the site. Usually this happnes in a few day.
If instead you are not a direct Datalogic customer, your credentials will continue to give you access to a basic account. To obtain the obsolete devices’ firmware we suggest to get in contact the dealer or authorized partner from whom you purchased the devices.
See also: Firmware downloads for obsolete Datalogic Mobile devices
Estou buscando um meio de atualizar os 14 aparelhos que tenho na empresa. Produtos do qual foram adquiridos em 2015 e só ano passado que iniciamos a utilização. No caso não tenho acesso a download de firmware pela conta e sem encontrar outro meio para poder atualizar os aparelhos.
Att,
Amilcar Bezerra
I am looking for a way to update the 14 devices I have in the company. Products of which were purchased in 2015 and only last year that we started using. In the case I do not have access to download firmware by account and without finding another way to be able to update the devices.
Hello @Amilcar_Bezerra_Amil
From your words, I gather that you did not purchase the devices directly from Datalogic. In such cases, your first option should be to contact your supplier, reseller, or the sales channel manager you used to purchase devices and ask him/her for the Firmware you are looking for. They should be
Only in case this route is not feasible, please open a request to our Technical Support by filling out this form (link) .
