I’m sorry but i cant find the Firmware for a Skorpio x3.
Not even here where it supposed to be https://partnernet.datalogic.com/#.
i need some help.
Hi @Paskal_Cielenga ,
please see the discussion Upgrade Firmware Skorpio X3.
if you still need help, I suggest you to open a support request at https://www.datalogic.com/ita/contatti/supporto-tecnico-cts-8.html , where one of our technicians can help you.
Hello @Paskal_Cielenga
look also at the post: “Upgrade Firmware Skorpio X3 - #12 by Simone_Callegari”
- open and register to https://partnernet.datalogic.com/
- follow: Technical -> Software Download
- search for “Skorpio X3 firmware”
The resulting page return all the available firmware download for Skorpio X3.
Simone
There are no any firmware for Skorpio X3 on Datalogic site for now.
Is there possible to get it (v.2.30) some way?
Where can we get the firmware?
The download section of the Datalogic Corporate Extranet website available at https://partnernet.datalogic.com/ is reserved to direct Datalogic customers only.
After the registration, you are enabled to a basic access that shows some public link and some documentation. In a second step, the website will recognize if your registration email is associated with an order and will give you full access to all sections of the site. Usually this happnes in a few day.
If instead you are not a direct Datalogic customer, your credentials will continue to give you access to a basic account. To obtain the obsolete devices’ firmware we suggest to get in contact the dealer or authorized partner from whom you purchased the devices.
See also: Firmware downloads for obsolete Datalogic Mobile devices
The firmware is removed from datalogic partnernet websites.
Can someone share it?
nkIntl.img Skorpio X3 Windows CE 6.0 International version 2.30
SKORPIO X3 WINDOWS CE 6.0 VERSION 2.30 FIRMWARE IMAGE (SEP 4, 2018)
skorpio_x3_CE6.0_ver_2.30
Hello
The Skorpio X3 Windows CE 6.0 fw is still available on the partnernet website.
After the login on https://partnernet.datalogic.com, select “Technical”, then “Software Download”.
On the Search field, enter “Skorpio X3 Windows CE 6.0”, then press the magnifying glass button for searching:
A list with all the FW for the Skorpio X3 Windows CE 6.0, including the most recent 2.30 version will appear:
If you require more specific support, you can get in contact with our local technical support team, by completing the module at this link (english version) . One of our engineers will provide you with all the information you need.
